Results 1 to 9 of 9
Thread: Vin# 1gchk23143f168478 Check Please!!!
    Dec 2008
    Youngstown Ohio
    Default Vin# 1gchk23143f168478 Check Please!!!
    Hello i am new here, but have been reading here for awhile. this forum has the best info out there. money cant buy info. this good! i just recently purchased a 2003 hd2500 dmax w/ the lb7 motor. a couple off days later i crawled under it and noticed some big holes in the transmisson tunnel. i think it has been converted from a manual to a allison auto??? you cant see these holes from in the cab because they put new carpet in the front to cover them. could someone please do a vin# check to provide me w/ a build sheet and any info they can. VIN# 1GCHK23143F168478
    Welcome aboard!
    You don't need a VIN check. In the glove box is a sticker with a bunch of codes on it. These are the RPO codes (Regular Production Options), and will tell you a lot more than a VIN check. The tranny code begins with an "M". List all the "M" codes and we can tell you what it came with.
    That said, holes in the tranny tunnel does not mean it's been switched. GM tools the tunnel die for both tranny options, and covers the holes as appropriate. It isn't likely the tranny has been switched, but there would be several other indicators if it had been. I think I'd be more concerned with the reason for the carpet replacement (flood, etc).
    Dec 2008
    Youngstown Ohio
    Default code
    M74 is the only m-code in the glove box. i greatly appreciate your help. what code would tell me if the truck has been switched from a maual shift transfer case to a push button? there is a 6x6 hole on the drivers side of the trans. tunnel. it is exposeed and still has black gasket material around it?
    Jan 2005
    Southern Indiana
    just VIS'd it. It came factory w/ the Allison and the push button t-case.
    Jan 2005
    Southern Indiana
    Ae7 - 40/20/40 Split Bench Seat With Front Leather Seating Surfaces Am7 - Folding Rear Seat
    Au0 - Keyless Remote Door Lock Au3 - Power Door Lock System
    A31 - Power Windows B30 - Wheelhousing & Floor Carpeting
    B32 - Front Color-keyed Floor Mats B33 - Rear Color Keyed Floor Mats
    B71 - Wheel Opening Flares B85 - Bright Body Side Moldings
    Cj3 - Air Cond., Dual Zone Manual (replaces Air Cond. In Pkg) Cmd - Assembly Plant - Flint, Mi
    C49 - Electric Rear Window Defogger C6w - Gvw Rating - 9,200 Lbs
    Df5 - Isrv Mirror W/compass & Temp Dk7 - Interior Custom Roof Console
    Dl3 - Osrv Mirror W/driver Side Auto Dimming, Pwr Fold & Adj, Heat, Turn Signal E63 - Fleetside Body
    Fe9 - Federal/ny/vt Emissions Ft2 - Arm Tors Bar Spring Adj
    Ft3 - Arm Tors Bar Spring Adj Gt4 - Rear Axle - 3.73 Ratio
    G80 - Locking Differential-rear Axle Hvy - Iden 2 Inch Body Raise,hd Model
    Jh6 - 4 Wheel Power Disc Brakes, Hd Kc4 - Engine Oil Cooling System
    Knp - Hd Aux Transmission Cooling Sys Kup - Throttle Control Electronic
    K05 - Engine Block Heater K34 - Cruise Control
    K47 - High Capacity Air Cleaner K68 - 105 Amp Delcotron Generator
    Lb7 - Duramax Diesel 6600 V8 Engine M74 - Allison 5 Spd Automatic Trans
    Nf2 - Federal Emission System Np1 - Electronic Shift Transfer Case
    Np5 - Leather Wrapped Steering Wheel Pdd - Color-keyed Carpet
    Py0 - Polished Aluminum Wheels Qiz - Lt245/75r16/e Als Bw Tires
    R9z - Poms Expedite-sold Orders Slm - Stock Orders
    Tq3 - Battery 770 Cca (dual) Tr3 - Chrome Grille
    T96 - Front Fog Lamps Ub0 - Am/fm Stereo W/cd Player
    Uq3 - Enhanced Audio Speakers Vb3 - Chrome Rear Step Bumper
    Vg3 - Front Deluxe Chromed Bumper Vk3 - Front License Plate Mount
    Vr4 - Weight Distrib. Platform Hitch Vxs - Complete Vehicle Label
    V10 - Cold-climate Package V73 - Statement Of Vehicle Cert.-u.s. /canada
    Xhh - Lt245/75r16/e Als Bw Tires-frnt X88 - Chevrolet Conversion
    Yd3 - Base Equip For Sch Gvw Pl-ft Ax Yd6 - Base Rear Spring
    Ye9 - Silverado Yhh - Lt245/75r16/e Als Bw Tires-rear
    Zhh - Lt245/75r16/e Als Bw Spare Tire Zy1 - Solid Paint
    Z82 - Heavy Duty Trailering Equipment Z85 - Heavy Duty Suspension
    1sb - Ls Decor Includes: * Air Cond, Dual Zone Manual * Dual Pwr Heated Osrv Mirrors * Rear Window Defogger * Am/fm Stereo W/cd Player * Chrome Styled Steel Wheels * Electronic Speed Control * Power Locks & Windows * Remote Keyless Entry With Content Theft Alarm * Isrv Mirror W/compass &temp * Leather Wrapped Steering Whl * Body Side Moldings 1sz - Preferred Equipment Savings
    6gl - Front Spring 62u - Dk Gray Metallic
    69d - Dark Charcoal - Custom Cloth 69i - Dk Pewter Interior Trim
    7gl - Front Spring
    Feb 2001
    WI, USA
    NP1 is electric shift and NP2 is the manual shift transfer case
    2004 LLY SC LB
    ATS exhaust - BD LH Manifold
    Kennedy Diesel Mega Filter & Lift Pump
    Dec 2008
    Youngstown Ohio
    Default options?
    everything checks out guys!!! what a relief!!! thank all of you. wonder what the heck there is a 6'x6' hole in my transmission tunnel for, i can't figure it out??
    Jan 2007
    Somewhere between WI & WY
    Snow plow equipment???
    08 Blue Granite Silverado LTZ, DMax/Ally, CC/LB/4x4, Cab lights, Camper mirrors, Brake controller, Sunroof, Park assist, and skinny tires
    06 Jetta TDI
    00 Jayco 263RK (2nd home)
    upgraded to an "09" Ranger 619VS/full windsheilds, w/an ETEC 225HO, T8 kicker, Minnkota 101 Terrova, and Lowrance electronics.
    Real Trucks have LONG BEDS!
    Jul 2007
    Canada
    Quote Originally Posted by kawikid1425 View Post
    To quickly dispose of the whiskey bottles when the cops pull you over...
