Quote Originally Posted by Liftgate View Post
Hi Gophergunner. I have been reading the posts here and may have some help for you with the trans. part numbers for the 4-53. I have a 53 series SAE #3 housing too if you are interested. It is the housing that has the round opening for a trans with the SAE bolt pattern with 17 inch bolt to bolt pattern. The adapter adapts the rear housing of the engine to a standard GM bell housing to bolt up to a 4 bolt manual transmission with clutch and all. Not sure if the part numbers are valid anymore though. The adapter uses the standard rear trans mount across the frame. Good luck!
Well thanks for the info, but sadly my hopes and dreams of a Detroit powered pickup have been put on hold due to going back to school and spending too much time on my off-road project.
But i will keep this in mind if or when my project ever does fire up.
