TheDieselPage.com Forums
The Diesel Page Forums
2020 - TDP's 24th Anniversary
Go Back   TheDieselPage.com Forums > Advertisers > DieselPerformance.com
Reply
Thread Tools Display Modes
  #1
Old 01-27-2009, 02:53 PM
More Power's Avatar
Administrator
Arrow BD's Cool-It Intercooler
BD's new Chevy LB7/LLY Duramax Intercooler
Compressed air is heated air-and when you combine an aggressive fuel curve with elevated boost levels, high inlet temperature can result. That's why BD developed the Cool-It intercooler. With up to 57% more cooling surface area and an up to 33% thicker core, the Cool-It increases cooling effectiveness to approximately 90%, compared to only 70% for the stock intercooler. That can mean a temperature reduction of up to 200 degrees Fahrenheit over the stock intercooler! At the same time, the up to 36% larger inlet and discharge tubes can handle up to 100 psi of boost and over 1500 cfm, while holding pressure drop to less than 1 psi.
And with BD's new Chevy LB7/LLY Duramax unit having over 780 sq in of frontal cooling area and almost 2000 cu in. of cooling volume, that's an increase of 12% more area and 79% more volume over stock - 4% more area and 37% more volume over some competitors.
A direct, bolt-in replacement for the stock unit, the Cool-It is the best-looking, best performing intercooler on the market. Hoses and spring loaded T-bar clamps included in some kits. New manufacturing design makes all end tanks with exclusive cast-in one-piece internal support columns that increase tank stiffness and strength.
  • BD Intercooler w/ high efficiency w/low pressure drop extruded tube= 2.56 x 38 x 20.54
  • Frontal surface Area = 780.52 sq in
  • Cooling Volume = 1998.1 cu in.
  • Efficiency: >90%
  • Pressure Drop < 1 psi
  • Banks Tube and fin = 1.94 x 20 x 37.5
  • Frontal Area = 750 sq in.
  • Cooling Volume = 1455 cu in
  • Stock = 37.6 x 18.6 x 1.6
  • Frontal Area = 699.4 sq in
  • Cooling Volume = 1119 cu in
  • BD Frontal Area 12% More than stock
  • BD Cooling Volume 79% More than stock
  • BD Frontal Area 4% More than Banks
  • BD Cooling Volume 37% More than stock
  • More than 90% efficient; 10% more efficient than the next leading Duramax aftermarket intercooler
BD Diesel Performance
Toll Free. 1.800.887.5030
Unit A10-33733 King Rd,
Abbotsford, BC, Canada
V2S 7M9
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
