The purpose of the CDR is to prevent too much vacuum from being applied to the crankcase. When it fails, too much vacuum pulls air and dirt past the crankshaft seals and sucks excess oil into the intake. If it plugs (unlikely) then blow-by will pressurize the crankcase and it'll leak all over. If you have excessive blowby, that can also result in excess oil in the intake.
