Results 1 to 19 of 19
Thread: What oil do you use?
    Feb 2009
    Tucson, AZ
    Default What oil do you use?
    I have 1500 miles on my new 2500HD, and I'm going to change the oil. I've been a hot rodder for 35 years now. The question is not about my timing on the oil change, but the oil that is the best for this new engine. What is everybody using? How long have you used it? Is there some oils to stay away from?
    I hope I've asked all the right questions, I'm sure there's a boat load of information in everybody's head in this forum, so thanks in advance.
    BBTank
    Jul 2007
    Canada
    Is it an 08 or 09 model?
    If so, make sure the oil is rated CJ-4 (Many are but not all)
    I'd go for Delo or Rotella
    Feb 2009
    Tucson, AZ
    It's an 08. I'm just wanting to do an oil change now, and wondered what every body here used. Not very many people in this forum, huh?
    The Corvette forum i use has tons of respones in 10 min., it takes 10 days on this forum.........It'll come around
    Jul 2007
    Canada
    Just a slow night...
    Owego, NY
    My personal favorites are 15w40 Chevron Delo 400 (conventional) and 5W40 Mobil-1 Turbo Diesel Truck (Delvac-1 Synthetic). Other popular choices include AMSOIL, Rotella, Mobil Delvac 1300 & Castrol Tection ... As Rabbler pointed out, be sure your choice is API CJ-4 rated. For more discussion on oils also checkout Bobistheoilguy.com
    Bill
    98 K3500 6.5,SOLD
    Jan 2005
    Southern Indiana
    I like mobil delvac non-syn.
    I also have traditionally used Chevron Delo 400 15w40 and have received excellent wear reports. However I'm planning to switch to Amsoil synthetic my next change for the synthetic advantages.
    2007 Classic LBZ CCSB D/A
    Jul 2000
    Gilroy, California, United States
    Talking
    I use Castrol 5W-40 full synthetic and run it for at least 15k miles. I use it because I can find it occasionally at the local Auto Zone, used to use Mobil 1 when Walmart carried it in the 5 quart jugs, perfect for my rigs, VW takes 5 quarts and Dmax takes 10. Now am, finally seeing Mobil 1 Turbo Diesel Truck (5W-40) at Kragen and I would use that also but have a stockpile of Castrol.
    mattb5150@hotmail.com
    1993 K2500 HD ext.cab 4x4 - SOLD
    2003 GMC K2500HD SLT EXTRA CAB/SB DMAX/ALLI, Bilsteins, Sulastic Shackles, Pitman & Idler braces, KD Headlight Harness, CAT filtration, Lift pump w/KD harness, Denali Door handles, Yukon exterior mirrors
    2003 Yamaha Grizzly 660 Stoopider FAST
    1996 VW Passat TDI 48mpg - SOLD
    My vote is for the Mobil Delvac products - stays in the engines under extreme towing conditions we create, even in high heat.
    http://www.mobil.com/USA-English/Lub...PC-10_FAQs.pdf
    May 2001
    Morgantown, W.Va. USA
    Rotella T 15w-40 every 5000 miles. I get it at Tractor Supply (TSC) at about $19.50 per 10 quart jug (2.5 gallons).
    JP
    Jeff
    2013 Caprice PPV 6.0L
    Mar 2008
    shell rotella 15w-40 you can find it everwhere if you need it
    ...and you'll need lots of it, because it (Rotella) goes away under moderate heat stress!!!
    (If you currently think your Duramax or 6.5L uses a quart every ____ miles, quit using Rotella and it will quit using/vaporizing oil...)
    Nov 2007
    New Orleans
    Rotella 15W40 Here, No Problems in 10,000+ Miles!
    07 Silverado 2500HD - LMM Diesel
    Feb 2009
    Tucson, AZ
    Well, no offense guys, but you haven't helped me one bit. You guys are all over the map. Well, at least on oil. I'm suprised that there wasn't 4 or 5 folks that liked the same oil. seems that everybody has the one that works for them.
    Thanks for taking the time, really, I do appreciate it. I guess I'll have to find the one that works for me. Thanks again Tank
    If your still looking for input, I use Rotella 15/40. Tried Dello but it seems to disappear to fast.
    Jan 2002
    West Orange, NJ, USA
    Default Rotella Synthetic
    I used the Rotella synthetic when it was cheap at Walmart... it may still be cheap.
    I recall a discussion a couple of years ago, and there were a number of people who used the Rotella syn & were happy.
    FWIW, YMMV.
    Dave
    May 2005
    SE Wisconsin
    Amsoil 15W-40 in the K3500
    Amsoil 5W-40 in the diesel Jeep
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
    Sep 2006
    Brooker, FL
    Disclaimer: I was a field sales/products application engineer for Shell years ago, and for 30 years, was one of two U S Navy Fuels and Lubricants Technical Officers, so I have a fairly good background.
    The Shell company philosophy is not to make a product with dazzling specs, but one with the fewest shortcomings possible. I use Rotella T 15W/40 in both the motorhome (6.5L TD) and the van (6.9L NA, 150K mi.). The only alternatives I would use are Kendall Super-D 3 or Mobil Delvac 1300. I had an '81 Nissan Maxima 2.8L NA diesel, on which I put 275K miles; the only maintenance was a new set of injectors. My sister bought the car and put on another 300K. It's never been apart, still going at 700K. Super-D 3 30 the whole time.
    Synthetic in diesels is a luxury, because the oil generally needs to be discarded due to contaminant levels and the depletion of the additive package long before the base stock is in danger. My opinion might change if it's proved that the ULSD cause less contamination (as I think it will). I change at 4K miile intervals in the motorhome because most driving is interstate. The van, every 3K.
    To address Mark's comment about high consumption with Rotella T 15W/40: There are times when consumption will be higher due to heavy loads. This is usually desirable as it's usually from oil on the cylinder walls, which minimizes scuffing. I'm sure times have changed, but heavy loads with Delo back in my day caused other issues.
    To sum up, any oil meeting CI-4 is more than adequate. CI-4+ is better, CJ-4 (Rotella T and Delvac), still better. This assumes changing at the manufacturer-recommended intervals, keeping in mind that most vehicles are operated in conditions the owners manual would define as "severe".
    I use Amsoil in everything in my stable. I had to convince myself through UOA to extend my OCI but it does work and I convinced myself. I now do 15k miles on my oil then change.
    [CENTER]2005 Silverado 4X4 CC LB LLY [/CENTER]
    [CENTER]Air Lift Bags, [COLOR=black]Amsoil F2B[/COLOR], KB IOH Kit, BD Manifold, Fumoto Valve, PCV Reroute, Resonator Plugged, Mag-Hytec Diff Cover & Trans Pan, PPE X STD, 4" SS Magnaflow Kitty Ran Off[/CENTER]
    [CENTER][URL="http://www.duramaxfilters.com"]www.duramaxfilters.com[/URL][/CENTER]
