Hi
I had a Dtec fail after very little use,it is in my tow truck which dosn't get used very much,probley less than 2000 miles.It was mounted on a remote heat sink.Looking back i believ that it had issues right out of the box.
Stanadyne had plenty of time to build a better PMD,but never bothered till a fairly reliable aftermarket one was avalible.
If you have a EFI pump,keep a spare PMD with you at all times.I'v only had my EFI truck for a little over a year and had trouble with both the stanadyne and the aftermaket PMD.
Take your chances with either,the time will come that you will have to replace it.
Thomas
