I bought my 1995 2500 series 4x4 truck a couple of years ago and have not had any stalling problems until now. It had 108k when I got it and now has 130k. It has the L65 engine and a green tag pump on it.
I turned off the highway onto a side road and it quit under power just like you turned off the key. I tried to restart it and it started right up, drove it 50 feet and quit again. Same deal on the restart and drove it 2 miles and quit again. One or two more start/ drive 50 feet/ quit and then no restart. Had to tow it home. This is the first and only trouble like this since I have had it.
Checked the lift pump, filter and fuel to IP. All ok. Cracked an injector line, cranked 30 seconds or so and have no fuel to the injector.
Checked for codes and had only a code 78 as I had just had to replace the vac pump and had not cleared the code. No other codes. My truck is I think an OBD I model as it has the ALDL plug under the steering column and using a jumper wire I can read codes via the check engine light.
So, what next? Pull off the FSD and try retorquing the transistor mountings? Any ideas?
Thanks, Ron
