Cool idea! Sounds like you have a lot of the basics covered.
One problem that I see and that you are aware of concerns the blow-off valve: there are no throttle plates or intake vacuum on a diesel. On a gasser, when you mash the go pedal, the throttle plates open up and the intake vacuum disappears as the engine starts to ingest as much as air as possible. When you suddenly let off the go pedal at high rpm, the throttle plates close, but the supercharger is still producing boost, but it has no place to go, so it goes out the blow-off valve (relief valve).
On a diesel, there are no throttle plates, so the engine is ingesting as much air as possible at all times. When you mash the go pedal on a diesel, all you are doing is adding fuel and advancing the timing a bit. When you let off the go pedal suddenly, the supercharger is still producing boost, but that's not a problem, as it will just push through the cylinders anyway. In fact, this could be good, as it will push out the exhaust gases and cool things down. So a blow-off valve won't be any good with a diesel.
I suppose you could set the blow-off valve for a max psi pressure...but I don't think they're designed to leak off a little pressure over a long period of time...I'm not sure.
I think you would have to experiment with pulley diameters and control the speed of the supercharger to find the right boost pressures at the right rpm.
Edit: after re-reading your posts, it sounds like you already know this...I jumped the gun in posting. Oh well.
Reason: Didn't read original posts very well
