'BRM' - Remember, the Duramax is a fly-by-wire system that doesn't provide for simple mechanical substitutions of controls...!!! The more I think about what you are planning, the more questions I have to ask...
- Do you intend to swap over a Duramax gauge and control cluster? (By doing so, you'd have a 'factory' tach, oil/water/tranny temp gauges, warning lights, including SES when codes are set...)
- An OBD-II interface (port) would be verrry advisable for monitoring / tuning ECM/TCM functions - a likely need during the fine tuning of your new drivetrain- which calls for a good portion of the factory wiring harness to be swapped over as well;
- whats the plan for converting the fuel tank(s)? Senders?
- whats the plan for your new accelerator pedal? Cruise?
- by the way...cooling system, intercooler, oil/trans coolers, A/C provisions, etc. etc. etc.
- where are you going to get your vaccuum for the current braking system? Personally, I'd find a air/hydraulic system from a Kodiak and retrofit discs all the way around...
In fact, have you considered buying a wrecked or high mile C4500 Kodiak cab/chassis in its entirety, using the donor engine, cooler stack, HD torque converter, Allision 1000, the complete wiring harness, ECM/TCMs (set up for a 10K# truck with 17500# + GVW expectations and 19.5" wheels/rubber), an awesome 4 wheel disc air-over-hydraulic braking system, often a factory exhaust brake (!!!), dual diesel fuel tanks, dash and gauges, etc, etc, ...?
I think a 2WD C4500 or even C5500 Kodiak would be a cheaper and a better donor for all the needed parts than any K3500 or K4500 truck which will have '4WD-isms' (including a transfer case you don't need) built into the chassis, ECM/TCM programming...etc...etc...
MorePower's experiences swapping a Duramax drivetrain into an 80s truck (LilRed) will be invaluable for this project...starting with an engine, and working your way out may be the most expensive way to approach this swap.
Swapping in a Duramax drivetrain, electronics and controls is more of 'setting your old motorhome over the top of a new drivetrain' than it is about swapping an engine into the place of a tired 440ci gasser.
Think MONSTER GARAGE... Then ask yourself - WWJJD? (
What would Jesse James do?)
