98 oil pump for 95 6.5 (929) block?
Read in somebody's post (can't find it now) suggesting the 95 oil pump could be replaced with a 98 pump during a rebuild to increase running oil pressure. So.... I ordered one.
Now I'm wondering if that was so smart.
Will the oil cooler bypass and oil filter bypass valves in the 95 block function properly with a higher pressure pump? And, would the 95 oil cooler and cooler lines handle it OK? The oil pan in the 95 and the 98 are the same, according to the parts catalog.
Would there be any other weak spots in the 95 (929) oil gallery that might be affected by the higher oil pressure from a 1998 oil pump?
Black 95 6.5TD, 929 block, 173k miles, 65k on IP, 48k miles on self-rebuilt engine done in '09, 6 L&S Full-torque inserts in outer main crank holes, Clearwater heads, Fluidamper, rebuilt NV4500, 3" downpipe, 4" exhaust, no cat, dual T-stats, 9 blade fan, spin-on 180 degree clutch, Heath hi-flow water pump and turbomaster, PMD relocated, OPS relay mod, Heath PROM upgrade, and Kennedy headlight harness upgrade soon. Now use semi-syn Lucas 2-cycle oil every fill-up which greatly reduces the frequency of DTC 35-36 codes the PCM/ECM throws.
