I have a 2001 with 155.000 miles. It is blowing excessive black smoke and has had a PO234 code for overboost. Running down the highway at 70-72 with the cruise set it will blow smoke every time the boost goes above 10 psi. I had a couple of holes in the drivers side intercooler tube welded up just before the code started. I am trying to check my waste gate actuator. When I applied about 30 psi shop air I couldn't hear any air leaks but it took about 40 psi to move the rod. The waste gate arm only moved about 3/8". Is this all that it should move? I suspct that I might have multiple issues, possible some bad injectors also. Any help would be greatly apprciated
Tom
My thanks to the author. My only comment/ warning to others is that the valve covers on the left side of the truck are a lot closer than on the right side making it really hard to get the back bolts in and out of the upper and lower valve covers.
This was my first experience working on a diesel other than routine maintennace items, although I have worked on gas engines for a long time. I'm sure that I will probably have to replace the other 4 injectors in the future, but this will give me a chance to save smoe money first. My naxt project is to replace the rear half of the transfer case and put in the Kennedy plate so I don't get another hole. Does anyone know of a paper filter that will fit on a K&N cold air kit? Otherwise Iguess Iwill have to see if I can put the factory stuff back in.
