Results 1 to 8 of 8
Thread: 95 gmc 2500 Parts
    Default 95 gmc 2500 Parts
    Just broke the crank in my 2500 extended cab long bed.
    Heath Diesel PMD relocation Kit $200
    triple gauge pod with autometer gauges $100
    4l80e shifted fine in the truck $300
    4" exhaust with 3" downpipe and cat delete $100
    If you need anything else just let me know. It will be heading to the crusher soon.
    edit: Didn't realize that the location was not up there. Greenville SC. will ship from 29607
    Location?..........
    Default parts for sale
    Hi
    Im interested in the gauges and posibly the down pipe if you will seperate it from exhaust,i don't think i could afford to get the whole system shipped to my address.
    Let me know.
    Thanks Thomas
    Jun 2004
    central la.
    pm me if you still have the gages
    Thanks OM
    1993 C2500 HD 6.5 TD TH400 200,000+
    1978 C30 repowered W/6.5 TD turned up max 4 spd
    1996 c3500 cc srw stock sold
    1987 mercedes 300sdl
    Festus, MO.
    Does it have electric mirrors?
    I need the switch that adjusts them.
    Hi
    Havn't heard back from you.Are you selling parts?
    Thanks Thomas
    Jul 2002
    Michigan
    If you still have the truck I am in need of the A/C compressor bracket [casting] bolts to the head. And the vacuum pump bracket mounts to bottom of the A/C compressor and water pump studs and the vacuum pump bolts to the bottom of the bracket with three bolts [stamped steel ]
    The numbers on the A/C casting are 15592139 they are on the side that bolts to the head. The stamped steel bracket has some odd numbers on it also on the back side 06895 and the word Radar on it. I could also use the power steering pump lower bracket, it bolts to the front bottom toward the block of the pump with 2 bolts and has an L shaped piece that bolts to the side of the block no numbers on it anywhere. I could use all the attaching bolts also. Let me know how much and the shipping cost to 48174 zip code.
    Thanks ,Tom
    May 2001
    Morgantown, W.Va. USA
    I'm looking for some steel wheels to use in the winter time, if your 95 wheels will fit my wife's '04 2500 Suburban maybe we can do some bidness.
    Jeff
    2013 Caprice PPV 6.0L
