If there are no codes then the PCM is not seeing it drop out of lockup unexpectedly. So, if it is dropping out, it is expected. Look for a flaky brake pedal switch or a flaky coolant temperature sensor.
My experience is that the #9 resistor can make the throttle on some trucks touchy. Whether or not it could be the cause of the trans issues is a good question...
