I am in need of the A/C compressor bracket [casting] bolts to the head. And the vacuum pump bracket mounts to bottom of the A/C compressor and water pump studs and the vacuum pump bolts to the bottom of the bracket with three bolts [stamped steel ]
The numbers on the A/C casting are 15592139 they are on the side that bolts to the head. The stamped steel bracket has some odd numbers on it also on the back side 06895 and the word Radar on it. I could also use the power steering pump lower bracket [stamped steel], it bolts to the front bottom toward the block on the pump with 2 bolts and has an L shaped piece that bolts to the side of the block no numbers on it anywhere. I could use all the attaching bolts also. Let me know how much and the shipping cost to 48174 zip code.
Thanks ,Tom
These parts will be found on a 1988-1995 6.2L or 6.5L turbo or N/A
P.S. You can PM me if you prefer. I have some new bosch injectors new 60-G glow plugs and pre '95 glow plug controllers and a couple rebuilt never used DB 2831 5088 and DB 2831 4911 injector pumps if you are interested in a trade. Let me know what you need.
