Thread: Duramax swap - fuel tank question
    Default Duramax swap - fuel tank question
    doing a duramax converson 1997 3500 anyadvice on mounting new fuel tank it is longer
    Have you though about just swapping the sender package? If the mounting flange is different, you could still cut out the flange and weld it into the original tank.
    Feb 2009
    ZEPHYRHILLS, FL
    I kept the origanal tank in mine, just removed the old 5/16" return line and opened it up and put a 1/2" steel tube down through it. And if you get EFILIVE you can re-calibrate the fuel guage to work with your existing sending unit. I persoanlly kept my 95 cluster to avoid many of the associated tasks that came along with swapping the cluster.
    1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, 3.42 gears, 261 T-case
    Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4 and a PI ML converter
    DIAMONDEYE 4" exhaust with a CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump and pump rub kit.
