IIRC, it had something to do with the convertor locking up while in neutral and the tranmission cold mode to help warm things up quicker on cold starts.
An Allison engineer and I were talking about this during a traning session last winter. But I can't recall the whole explaination he gave me. It was more then just poor quality lines though.
Hmmmm. This is interesting....And counterintuitive. During the cold mode (warm up mode), the TC remains open to expedite transmission fluid warming. The open converter allows for more fluid friction. Locking the converter would reduce this effect. Although there is very little TC resistance in neutral, it is still more than none.
Poor line quality. The line components are capable of handling significantly more pressure than the tranny will ever produce. The failure is at the crimps, lending to the likelihood of a question of quality. This isn't new. 6.5/2L oil cooler lines saw the same process. GM went cheap with the lines. Simple as that.An Allison engineer and I were talking about this during a traning session last winter. But I can't recall the whole explaination he gave me. It was more then just poor quality lines though.
Although we shouldn't have to mess with this, the best solution is to just replace the crimp connection with a known quality repair. I recommend using Aeroquip type hose fittings, with a flare on the line. It is not expensive to do (you can do it yourself, or have any speed shop or AG supplier do it), and will never have this problem if done correctly. A second option is the same for 6.2/5L oil cooler lines. Remove the crimp collar and use hose clamps on the barb. Less permanent, IMO, but better than continually replacing the lines waiting for GM to get it right.
Just curious...does anyone know what the maximum pressure the transmission cooler lines will ever see?
2007 GMC 2500HD LBZ, 4X4, CC, SB
Scott
St. Louis, MO
I've done the same fix (with two clamps side by side on each barb) on my daughters Saturn and Wife's Impala .. haven't had one come off yet but I still keep checking them frequently for any signs of seepage ... Several years ago I used the double clamp fix on a low side AC line for my 85 golf diesel.. a new line from the the dealer was over $100 .. I evacuated and recharged the system and it was still working when I sold the car a few years later..
Bill
98 K3500 6.5,SOLD
So here's my attempt at a fix...
First I used a tube cutter to cut the tubing as close to the hose crimps as possible to get the hose section out of the line.
Then I went to town and got a piece of braided hydraulic hose made up with compression fittings. And just for the record, I was told these compression fittings are supposed to be able to handle 3000 psi or more, as they are regularly used with agricultural equipment. Thats what the guy at the parts store tells me anyways.
And here it is just loosely assembled, I won't tighten the fittings up until its all in place and fits properly into the truck.
I hope these work, well I'm quite positive they will hold, I just hope they fit in properly. I just need to go to a hunting store and get a wire brush for cleaning shotguns and scrub out the new hydraulic hose to make sure I get the loose bits out of it. Shortly after I install them, I will be taking my truck to the dealer for transmission service.
I do have another line to do, just took pictures of the one though.
Looks Great .. excellent idea!![]()
Bill
98 K3500 6.5,SOLD
Excellent job, great photos. Please update and let us know how it is progressing.
Splitrimz
1994 C3500 6.5TD CREWCAB DUALLY, Heath Turbomaster, cone style cold air intake, PMD cooler mounted under grill, Banks boost and exhaust temp gauges, OPS bypass, Air Lift rear bags.
2006 LBZ LTD, 4WD, CREW CAB DUALLY.
+1. I need to do a permanent fix for mine and like the way this looks.
Ambient temps here have warmed up a bit and my leaks are not nearly as bad. (Before you ask, yes, I did check the fluid level). Drove the truck to Vegas this week where it was in the 60's and had no leaks at all. I think the cold temperature theory has legs.
Any reason you didn't go with flare fittings? Seems to me the aluminum tubing is the softest thing in the mix, which, I'd think, would make flares preferable to compression fittings.
This is why I remain skeptical. The fittings are certainly rated and capable of 3,000 PSI. That is, if they are used with compatible line, which should be annealed steel tubing. Using compression fittings on aluminum lines (or soft steel) in a high-vibration application (like anything automotive) is not advisable. Swaged or flare fittings are always the preferred method in this case. It looks good, but I think it'll leak, and perhaps be worse than the current option from GM. I'd be concerned with a blow-out, compared to the minimal leak you are having now.
I have heard GM issued a bulletin last year relative to leaky transmission lines on our trucks, specifically identifying 2006-2009 model year vehicles. Within that bulletin, they indicate the concern (line leaks) are more prevalent in the cold.
GM released new transmission lines in service that are supposed to be better than the old ones.
20759971 - Pipe Assy, Upper / outlet ($28.07)
20759972 - Pipe Assy, Lower / inlet ($25.60)
20759973 - Hose Assy, Trans Fluid Aux Inlet ($20.46)
My 2006 has developed a line leak with 45k miles on it. I went around the bush with the stealership yesterday about this and the service manager said the best they can do is get GM to pay for the parts if I pay the estimated $270 to R&R the effected lines. What a deal (sarchasm)... I suspect the dealer was going to eat the cost of the line/s just to get some billable labor on the clock.
Funny how a powertrain leak isn't covered by a powertrain warranty... but hey, they finally 'fixed' my intermediate steering shaft the 4'th time in for the same issue. If this is the way of 'the new GM', my `06 was my last new GM purchase.
Would you know if those part #s are good for an 07 Classic
BarryUSN (Ret)
07 GMC Classic,LBZ,CCSB,4X4,SLT, 60K mi, Edge Evo Race w/cts, EGR Blocker, PCV Reroute, Helmholtz Plug, DE Down Pipe and Quiet Tone 4" TB Exh, TransGo Jr, Allison Deep Pan, Suncoast Filter Lock, PPE Airbox Mod, Amsoil Fluids, Formula One Tint, Undercover Tonnau, H2 Wheels, 285 Tera Grapplers, Fab Four Rear Bumper, Weather Tech SWD's, Sprayin Bedliner, Garmin Nuvi 1490T, Pintle Hook, PPE Tie Rod sleeves, Cognito Pit/Idler Arm Braces, Amsoil Dual Bypass Filters
06 Jetta 1.9L TDI,DSG, RC 1+ tune,EGR Delete, M101A2 3/4 ton trailer,NRA Benefactor Member
As far as I know, the part numbers I listed should work for 06-09 model year trucks. The prices I have listed are stealership cost, so expect a hefty markup if calling your local parts department. Or you can get them for the indicated price at gmpartsdirect, if you pay shipping and don't mind waiting until they get around to shipping them out. I had one order from gmpartsdirect take about 3 months to show up last year; luckily I wasn't in a hurry for the parts and (for what it's worth) you're better off using a Ouija board to figure out when the stuff will show up because if you call them you pretty much get the "It will get there when it gets there" response.
IF any of you guys have the stealership do the work on your rig, make sure they use these part numbers and NOT the previous vintage lines. Sometimes changes go through where dealer inventory of old / obsolete stock can be exhausted before they start using the replacement part. If they use the old / obsolete part, you'll just find yourself going back to the well later to do it all over again...
I was FURIOUS when I had mine in the shop for this two years ago. Less than 20K on the thing and the lines were leaking! The lines are 'consumable' and therefore not covered was the story I got.
Almost $600 bucks for the fix (THAT I SHOULD HAVE DONE MYSELF). If it wouldn't have been in the 20's outside, I'd have done it myself! Fortunately mine aren't leaking (YET!). My buddy has an 06, and his were leaking when he bought it last year. They were replaced then. They are leaking again. I'm going to give him those numbers so he can make sure that they are fixed 'correctly', or at least with the correct parts.
Scott
St. Louis, MO
The lines are steel of some sort, magnet sticks to them anyways, so I'm not too scared of using the compression fittings.
I've used these compression fittings before on higher pressure lines, they work well for agricultural equipment so I know they will hold the pressure and vibration.
One other fix, as recommended by an aircraft mechanic, was to weld a JIC fitting onto the tubing and then simply have a couple short hoses made up with the appropriate fittings.
I have not put them on my truck yet, waiting until the next oil change. Then shortly after I am taking my truck in for tranny fluid/filter change.
Hell, when are they going to step up and fix them? 500 bucks and mine still leak!!!
Scott
St. Louis, MO
My '06 is leaking - again...![]()
