Results 1 to 11 of 11
Thread: Photo of my 83 in its prime
    May 2009
    NH & Eastern NY
    Default Photo of my 83 in its prime
    This is what my 1983 GMC looked like about 15 years ago. The winter after this was taken, I had a small accident and had to start replacing body panels. I parked it, went off to college and only gave it minor attention since. Unfortunately I realized to late that when a vehicle is parked outside, unwashed after a salty winter, it will continue to rust uncontrolably. She now needs a cab too. Fortunately, the frame is in great shape as well as the suspension and axles. Still a good soild platform to build upon.
    I drove the truck for a few years with the orginal 6.2L diesel, and re-powered it with a 454, which was a big mistake. It still has the 454, but I intend to re-power (again) with a 6BT or 6.5 with turbo. Hopefully I will get to start restoration this year. Need some shop space first though.
    Nice shot of your truck - back in the day. Like the look too.
    These trucks are truely classics and endure time very well.
    The style is still popular even today.
    My love in that body style is the 3+3 cab Duallies and the Blazer/Jimmy.
    Great piccy
    Robyn
    Nov 2006
    Kelowna, BC
    Thumbs up
    wow, very nice looking truck. need more of them around.
    May 2009
    NH & Eastern NY
    Thanks guys!
    I want to restore the old girl and get her back to the exact look as in the picture. I want to do it right, document it well and take my time, focusing on the details. Which means I need a dedicated shop to do it in. Still working on that part.
    At the time that I parked it, I was young and stupid, and a hack of a mechanic then (not that I'm much better now!). I also completely ignored some simple things that would have made the resto so much easier now. With a little time and very little money, I could have at least saved the cab. Too much time spent chasing girls, drinking and craming for exams...
    Sep 2006
    Quote Originally Posted by crashz View Post
    Though a bit more complicated, you won't be dissapointed if you go with the 6BT, especially if its behind a manual transmission.
    1990 ¾ ton 4x4 Chevy Suburban
    -Gear Vendors Overdrive
    -Upgraded Holset HX-35 turbo
    -NP205 iron transfer case
    -3.73 gears
    1982 ½ ton Chevy Suburban
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    May 2009
    NH & Eastern NY
    Edahall,
    I may have access to a 5.9 with 5 speed manual transmission. I was hoping to talk to you, as you have done this swap into this body style truck before. Plumbing and wiring should not be overly difficult, however I'm curious as to the mounting position and motor mounts and well as cooling considerations.
    Sep 2006
    Edahall,
    Pictures are worth a thousand words so I'll take some pictures and post them so you can get a better idea on the swap and what was involved.
    As far as cooling, I'm using a 4 core Chevy 6.2 Diesel radiator. I've heard that the 6BT puts out less heat than the 6.2 at the same power levels. I have never had an issue with cooling even while pulling heavy loads. I'm also using the stock direct drive fan that came with the Cummins. I'm not using an intercooler.
    -3.73 gears
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    Sep 2006
    I finally got around to taking some pictures of my setup.
    Motor Mounts
    Engine compartment
    Clearance between fan and radiator
    Extra crossmember welded in
    Sep 2006
    NV5600 Transmission, NP205 Transfer Case & Gear Vendors
    Clutch master cylinder from a Jeep CJ
    Transmission & Transfer Case Shifters
    May 2009
    NH & Eastern NY
    Thanks Edahall! I'll have to view them at home since the images are blocked here at work.
