Timing retarded
Am pretty sure my timing is a bit retarded after completing my rebuild. With engine cold and in neutral, I run up the rpms to about 2k and it breaks up just a bit. I also get no black smoke whatsoever under full throttle pulling a 3 horse trailer loaded with one horse or a ton of hay in the bed.
If I turn the pump slightly to the passenger side to advance the timing, how far should I go? 1/8 inch? 1/16 inch? Or what? Would 1/4 inch be too much?
Black 95 6.5TD, 929 block, 173k miles, 65k on IP, 48k miles on self-rebuilt engine done in '09, 6 L&S Full-torque inserts in outer main crank holes, Clearwater heads, Fluidamper, rebuilt NV4500, 3" downpipe, 4" exhaust, no cat, dual T-stats, 9 blade fan, spin-on 180 degree clutch, Heath hi-flow water pump and turbomaster, PMD relocated, OPS relay mod, Heath PROM upgrade, and Kennedy headlight harness upgrade soon. Now use semi-syn Lucas 2-cycle oil every fill-up which greatly reduces the frequency of DTC 35-36 codes the PCM/ECM throws.
