Now might be a good time to get the Mag-HyTec pan, which uses an O-ring, and has a (I'm NOT making this up!) REAL DRAIN PLUG! Its baffling and fins along with its aluminum construction really make a difference in cooling.
Shoving my 8T motorhome (with about 100 sq. ft. of frontal area) loads a tranny, and the M-HT pan has lowered temps underway by 20°F. This is substantiated by the fact the temp when creeping in a long highway backup runs around 160°F. When traffic speeds up, it goes back down to the usual 140-145°F. Part of that is due to the pump circulating more, but it's much less than the engine temp; the cooler is in the (very large) radiator.
