Results 1 to 6 of 6
Thread: Spare block heater installation
    Default Spare block heater installation
    Thank you to all that responded to my other thread. After only one week of installation of new block heater it went bad, heater is testing open circuit. Truck starting in morning only by the grace of God, will be replace existing heater and while at it was going to put in a spare. If someone could tell me good location that would be great. Current heater is on left side just fwd or oil filter. 1985 Silverado 6.2. Thank you All. Dave
    The cords (replaceable) fail much more frequently than the heaters themselves...
    Feb 2011
    Annandale Minnesota
    On the 6.2s and 6.5s I always install a second frost plug heater on the passenger side in the center? frost plug. I have to make a custom starter bracket to clear the heater. I do it when the engine is out of the truck. You would have to take the starter off to get the second one in with it in the truck. There is a couple pics of it in the starter thread last week.
    98 K2500HD 6.5td 4l80e 4.10 245-16
    97 K3500 C&C 6.5td 4l80e 4.10 225-16
    97 K2500HD 6.5td 4l80e 3.70 33-12.5-16.5
    95 k2500HD ext. cab 6.5td 4l80e 4.10 265-16
    95 K2500LD 6.5td 4l80e 3.70 245-16
    95 C2500 ext cab 6.2td NV4500 3.70 245-16
    94 K3500 srw 6.5td 4l80e 4.10 245-16
    94 K2500HD 6.5td 4l80e 4.10 265-16
    93 K2500HD 6.5td 4l80e 4.10 245-16 farm truck
    92 K2500HD 6.5td 4l80e 3.40 265-16
    87 Monte Carlo SS 305 200r4
    81 Olds Cutlass Supreme 3.8 buick t200
    GMTD scantech tech1 w/mass storage
    Default Block heater
    Ya tested at block heater itself open line!
    Feb 2011
    Annandale Minnesota
    Good quality replacement parts seem to be getting harder to find. I've run nothing but napa frost plug heaters for many years without a failure. That doesn't mean that they didn't change manufactures and quality. Everything seems to be driven by price not quality.
    Default Thanks to all
    Ran out of time to explore options for spare heater so only put in one. Thank you everyone that replied. So far so good! Dave
