Until recently, I had a stock 2002 crew can dually 4x4, with the LB7 Duramax engine with auto (Allison) transmission (which I had purchased new 9 long years ago). I loved that truck almost beyond reason. Not only did it have a tremendous amount of power for pulling our 6 horse trailer fully loaded, but it was ALSO very, very quick off the line (both empty and, to a lesser degree, loaded), from a dead stop. If I wanted to "tromp on it" a little bit, my 2002 was "almost" as quick as a gas engine, off the line. Although it didn't have that big "surge of power" feeling that a gas engine gives you when you floor it; the actual quickness, 0 to 60 or 70 miles per hour "in a heartbeat" speed that my diesel truck gave me was freaking amazing (for a diesel). I had never driven a diesel that came even close to its "off the line" responsiveness. I didn't feel any turbo lag; it just quietly "got on down the road" when I put the pedal to the metal. Sadly, due to some temporary financial difficulties, I had to sell my 2002 truck for some quick cash. Now I am looking for a replacement. After much research, I have decided to buy a 2006 or 2007 LBZ, since I can't afford to buy new right now, and the LBZ seems to have the least trouble, and the most power of any of the newer used Duramaxes available. *I am due to test drive a*LBZ 2007 Sierra on Saturday. Although it has taken me a long time to get to my question--here it is: *I know 2007 has more emissions*
stuff than my 2002 did. *But, I also know the 2006-2007 LBZ has quite a bit more horsepower in the stock LBZ engine than my 2002 LB7 did. *So, should the 2007 (unloaded) feel similarly quick off the line as my 2002 did? *I'm travelling quite a distance to try it, and I don't want to turn my nose up at it -- if it is not quite as quick as my 2002--if that is normal behavoir for the 2007's. *The reason I want opinions is because I tried a stock 2006 LBZ the other day and wad very disappointed. *It felt pretty doggy and non-powerful off the line. *It didn't come within a country mile of the responsiveness off the line of my 2002. I turned my nose up at the 2006; thinking the engine had been abused. *Was I right-- or will all 2006-7 LBZs feel doggy to me, compared to my pre-emissions 2002? *I've tried to compare 0-60 data; 1/4 *mile data etc. for stock LB7/LBZ trucks. *By the numbers, the two trucks ought to be very close in both quick responsiveness and power to pull a big load easily. *If that's true, then the 2006 I tried was just used up or ill-tuned or ??
Rather than relying on "data" about the two engines, I would love to hear real world experience from those of you who have had*experience owning / driving the STOCK 2001 or 2002 LB7, then later bought a STOCK LBZ, and ran it that way (stock)--at least for awhile. *If there are any of you out there, give me your thoughts on how the two trucks were in quickness off the line, and in pulling a load. *If you don't have heavy pulling information; that's okay, too. I'm fairly confident that the 2007 truck will be strong enough with my trailer--I would still like your opinion about off the line quickness between the two.*
When I go to test drive the 2007 on Saturday, I don't want to expect more out of it then it is going to give me; and then falsely think that the engine is bad just because it doesn't feel "quite"*as good as my beloved 2002 did. Thoughts, anyone? PS I know proper tuning is key; but assume a 2002 and 2007 are equally well tuned, for this comparison. *Thanks!!*
and worst of all you are bound to get the wrong parts as someone wil undoubtedly associate it with the 2005 LLY sooner or later. If you call it LBZ it will live happily ever
after and you will never get the wrong parts...
