Results 1 to 14 of 14
Thread: master window switch?
    Default master window switch?
    Hello All,
    The windows on my 99 Suburban are not going down when I try to open them with the master control switch. My first assumption is to replace the master control switch. But I want to make sure it is not anything else first.
    Symptoms:
    Windows sometimes do not go up or down with master control switch
    Windows will not go up or down when tried with switch at window
    Happens more when it has been very hot.
    If the master switch is faulty, will the other window switches also fail to work?
    Any suggestions will be greatly appreciated. Its a pita when you cannot put down the windows when its 99 degrees outside.....
    A
    1999(F) K1500 Suburban LT
    215K Miles, Remote PMD.3.42
    New Rhino LB, IP ,Injectors, and Glow Plugs.
    Turbo Master Boost Controller.3" DP
    The most common cause is simple. Connectors and/or contacts. Remove the switch cluster from the door, disconnect the connector and inspect. You will probably see a dull/powdery residue on the poles/slots. A light brush with fine sand paper cleans them up well. Flush with electronic cleaner spray. reconnect and try again. If it isn't working, completely, soak the cluster with electronic cleaner through every hole/crack you can find. Operate all the switches a few times while the cleaner is still wet (it dries very quickly). Flush again, drain, and leave overnight in a warm, dry place. This will clean the contacts, but leave the grease on the rockers in place. Connect and give it a try. You can disassemble the cluster and clean manually, but it is very tedious (many very small parts, most are spring loaded), and there is a high risk of breaking internal (non replaceable) parts. I have about a 50/50 success rate with the brittle plastic 10+ years old switches. Replace grease with synthetic dielectric grease (tune up grease). If you find burned contacts that won't clean up (or are burned through), you'll have to fabricate. I use parts from cannibalized old appliances, radios, and toys.
    Apr 2006
    Cedar Grove, NC
    I have to spray my switches with the electronic cleaner stuff every 6 months or so. I know they need to come out and be cleaned/replaced, but a shot of that stuff keeps me going. Try simply spraying them in place before you go too deep.
    Lewis
    84 C10 J code intake. Sold in 2020
    83 C10 Scottsdale w/veggie conversion. Lost in divorce 2015 but totally worth it.
    98 K3500 Silverado CC DRW, marine injectors, 4" exhaust (kitty cat MIA), boost and egt gauges, FSD relocated, #9 resistor thingy, reman Navistar block from Kennedy installed Jan 08, Reese Signature Series Gooseneck hitch. Lost in divorce 2015 but totally worth it.
    95 C2500 F code. Rebuilt GEP. Boost, EGT, and fuel pressure gauges. Redundant PMD with one behind bumper and one on firewall. Daily driver since Jan 2014.
    Default thanks
    Thanks for the input guys. Hopefully this will do and save me $100. Will I need to pull the inside door panel off to access the switch?
    A
    OK reread the post and you need to try this FIRST
    Replace the power window circuit breaker in the fuse panel. The windows are on a circuit breaker and not a fuse. HEAT and time can cause the breakers to open when they should not.
    Try this first and then read more of what I have here.
    __________________________________________________ ___________________________
    The way the window circuits are wired requires that all the contacts are working correctly, but not all the windows should fail at once due to a bad switch.
    If for example the master switch is not making contact when its in the neutral position, the individual switch for the particular window in question will not opperate the window.
    When the master for any window (drivers panel) is in neutral, the ground is routed back through to the main ground buss under the dash.
    There are no "Door grounds" and all the circuits ground back through the master switch.
    The BLACK wire/s in the switch harness that leads out of the door are GROUND #150
    The Pink wire is the hot lead (12V)
    When all the switches are in the neutral position, both motor leads are grounded all the way back through the master switch and to the BUSS BAR.
    Once a switch is toggled the power is then routed to either the up or down side of the motor and what was a grounded lead becomes a 12V feed. Reversing the side that has the power/ground reverses the motor.
    If for example one lead on a particular switch was not connected at the individual switch the master might only be able to run the window down or maybe only up.
    The MASTER switch always grounds both motor leads when its in the neutral position.
    This allows the single window switches to switch the ground/power between the two lines and run the window up or down.
    If none of the windows will work then the issue could be either the master ground or a power feed.
    The possibility of all the contacts being bad are remote.
    Yank the door panel and check to see if you have 12V at the large pink wire when the key is on, if not the issue is not the switch
    Good luck
    Missy
    Default great info
    Thanks for the reply Missy. Would you please elaborate on what the master ground is?
    Thank you,
    A
    Many of the accessories and the other goodies under the dash are grounded though a "BUSS BAR" device, usually located under the dash near the LH A Pillar.
    There will be several ground wires all plugged onto this little pronged device.
    Be sure to check the Circuit breaker before you tear stuff apart.
    If you find that a new breaker will not fix it, then take the LH door panel off and check 12V at the Large pink wire that feeds the switch.
    Good luck
    Missy
    Default circuit breaker
    None of the local auto parts store have a circuit breaker that looks even remotely close to mine in regards to the actual prongs. Also, the voltage is different. The circuit breaker next to it looked identical so I switch them. The other circuit breaker controlled the door lock. Door lock still worked after switch but no luck on the window. The window is not opening at all now. I will tear it open to see if I have 12V or if the cluster just needs to be cleaned.
    A
    Default remote now acting funky
    Notice the truck is past inspection so I picked up a window switch in a hurry since I am going on vacation on Saturday. Windows "seem" to work for now but my remote keys are acing odd. Press lock on the remote and the truck tries to unlock....Manually locking and unlocking the truck is fine. So do I need to reprogram my remotes to the truck?
    Thanks,
    A
    Default Ugh
    Went to program the keys and the windows did not go down.
    Hopefully I can find this buss bar and determine if I have a bad connection.
    I am definitely running out of time here
    A
    Default Found out the problem
    Well I discovered 2 problems:
    1. Listen to Missy
    2. The circuit breaker was loose.
    After scrambling through a ton on spaghetti I accidentally bumped the back side of the panel that holds the circuit breaker and the window started to work. I was holding down the window button while wiggling wires.
    If I pushed the breaker to one side the window worked. If I let go it did not. So for right now I have a piece of rubber pressed against the side of it to apply pressure. I will have to determine a more permanent way to correct this issue when I get back from the beach. Thanks to all that posted suggested and a special thanks goes out to Missy.
    Cheers,
    A
    Sounds like you need to tighten up the connectors in the fuse box.
    Glad it was as simple as a loose connection.
    The connectors in the fuse/breaker panel do a lot of heating and cooling due to power loading.
    Before you try to fool with the terminals in the panel, try this.
    Take the breaker out of the panel and "tweek" the spades slightly.
    OK the spades look like so _ _ now if you very gently twist these with a needle nose pliers, ever so slightly. Holding the breaker and looking straight at the ends of the prongs, tweek them like you were going to wind them in a circle. It will only take a little bit on each one to force them to fit more snugly in the slots of the breaker box.
    Trying to fool with the breaker box can have catastrophic results. Ask me how I know this.
    The other way is to grab each spade with two pliers, on opposite side and tweek them ever so slightly to make them sort of like a tiny V.
    The other way is to lay the breaker spades on a flat piece of steel, and using a center punch and a hammer (very small one) lightly dimple the spades. NOW I MEAN LIGHTLY just rasie some bumps that will cause the spades to fit snug in the terminals.
    The slight twist usually works about the best
    A few options.
    Good luck
    Missy
    Oct 2016
    Lincoln, NE
    Missy, I have an issue where all of the windows operate from the master but none of the passenger windows operate from the local switches. I replaced the master but it didn't make a difference. If I understand your post correctly, the issue is probably at the ground buss. Is that right.
