How do you disconnect the dtrl's on a 94 gmc k2500?
i want to put on the upgraded headlight wiring harness,. but drl's need to be diconnected,.
The head light switch is going funky AGAIN,. and it smells hot all the time,.
Thanks!
NIck
Thanks!
NIck
1999 chev suburban C2500
300,000 mi
I simply keep the parking brake down a couple of clicks. No DRL's on.
4doorTAHOE6.5TD
Pull the fuse.
2005 Chev K3500 CCLB
I didn't think 94s had daytime running lights.
From what I remember, that came out in the 96 model year.
My dad's 95 doesn't have them.
Maybe your switch is shorted on?
Joe.
2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
1996 Chevy C2500 6.5 auto Ext. Cab LB
300,000 mi
FYI - I've been running w/o my fuse for about 6 years, now. If I want my lights on, I turn them on. I don't need a computer to make that decision for me.
