Fuel pump help
I developed a hard start/stumbling issue last week.
Symptoms:
Once in a while it's hard to start, either warm or cold;
Idles just fine, will run fine for a while;
Develops stumbling and hesitation after hard acceleration;
Will smooth out when light on the throttle;
My first thought was a clogged fuel filter, but I only had 8,000 miles on the filter currently installed. However, to rule that out, I changed the filter, but it didn't help. In fact, it seemed to get worse.
Initial tests of the fuel pump showed good: I opened the fuel drain valve with the engine running, and it didn't stall. However, after changing the filter and driving it for a bit, I did the test again, and this time it did stall.
I have Kennedy's OPS harness, so I can tell when the pump is running. I can also easily push a button to manually run the pump, which aids in filter changes. I was able to bleed the system after changing the filter, but it didn't seem to have as much flow as normal out the drain valve.
I decided that it must be time for another lift pump. The first one I installed when I bought the Tahoe lasted 35K miles before it quit. This one had 45K miles on it.
I replaced the lift pump, it started right up, and ran great. I drove it hard several miles, and never stumbled.
Today I drove it again since changing the pump, and after a few miles, the same symptoms appeared. Now when I open the drain valve, the engine stalls again. It's hard to restart. When I do get it started it idles great, but after holding RPMS above 2500 for a while, it starts cutting out and acts like it is starving for fuel.
I don't seem to have normal flow out of the drain valve when running the pump manually. I added 5 gallons of fuel to the tank to make sure gauge is reading correctly (now shows 1/2 tank).
Fuel tank and pickup tube/sending unit were replaced 15K miles ago due to a leak in the tank.
I did verify that the pump is running when the engine is running. In fact, when I unplug the pump harness, the engine stalls out pretty quickly.
So, did I purchase a faulty pump? Or do I need to look elsewhere for a problem?
My plan tomorrow night is to disconnect the outlet side of the pump and try to pump fuel into a bucket to see what kind of flow I have. I'm thinking I have either a restriction on the suction side of the pump, causing it not to be able to pull fuel from the tank, or a restriction on the filter side of the pump, causing it not to be able to push fuel to the injection pump.
Any other insight would be helpful.
Thanks,
