Results 1 to 4 of 4
Thread: Help diagnosing a slipping 700r4
    Concord, NC, USA
    Default Help diagnosing a slipping 700r4
    Hopped in the '86, put it in gear, hit the pedal and it started moving but then started slipping. I didn't want to take it on the road for fear of not making it back home. So I don't know what it does as far as shifting. Couldn't tell if it was slipping in reverse.
    I've put 70k miles on the vehicle since I've had it so I don't how many are on the trans. Last time I drove it (a week ago), it was perfect.
    Pulled the dipstick this morning and I do see some black build-up - can't tell if it's anymore than the usual traces of residue. Normal??
    I have a dash trans temp gauge and it has never even gotten close to overheating. Usually rides in the 140 range.
    The fluid/filter was changed 17k ago.
    I've got a transmission pressure gauge that connects to the transmission port but I need advice on what pressures to look for AND if this would help in diagnosing the problem.
    Detent cable out of whack?? Haven't inspected yet.
    What should I check first? Change the filter/fluid? I can road test in the neighborhood first.
    Mark Chapman DP member #653;
    "Grease is good"
    Concord, NC, USA
    TV cable seems ok.
    Drain fluid and dropped pan. Found a loose filter! It didn't fall off but I could push it up and down a good 1/2 inch.
    There were some metal fragments (1/16" size) in the bottom of the pan - not a lot but it was more than the normal fine black powder.
    New filter, filled it up, test drove. Same symptoms: slipping in first and reverse when moving up my driveway. Drove down street and got a good 1-2 shift but it would NOT shift out of 2, at least getting it up to 30 mph. Seemed to also slip in 2 when I really gave it the pedal.
    Any thoughts???
    Last time really I drove it, it showed absolutely no signs of misbehavior. This just happened quite suddenly. I've had other 700's go out in the Sub and I guess it did just switch from good to bad suddenly.
    "Grease is good"
    Concord, NC, USA
    any thoughts anybody?
    "Grease is good"
    Metal junk is a very bad sign.
    Sounds like something broke.
    Possibly a sprag
    Gonna have to come out I'm afraid.
    Missy
