Definitely lift pump
I got the IP replaced on the Tahoe, and now she is running again. However, I'm still having fuel supply issues.
I now have a Racor filter setup with a fuel pressure gauge installed. I was able to watch as the fuel pressure slowly dropped to zero after running for about 30 minutes. I took the suction side of the pump loose and put a hose on it and dropped it into a bucket of fuel. It wouldn't pull any fuel. I then put my finger on the end of the suction hose, and I didn't feel any suction at all. Next, I disconnected the outlet side of the pump, just to make sure there was no restriction. I ran the pump again, and absolutely no suction at all!!
Apparently, these Airtex pumps I've been getting are pure junk!!
Any recommendations on replacement lift pumps? I know AC Delco, Kennedy's Duramax pump, and the Walbro pumps are all options. Any other suggestions?
I might as well put the best in after doing all this work!!
