Results 1 to 6 of 6
Thread: Rear Differential Fluids
    Enumclaw, Washington, USA
    Default Rear Differential Fluids
    I am going to change out my OE rear cover and go with Mag Hytech. The truck is used primarily for towing. I figure a little extra fluid won't hurt. Last time I changed my fluid I used the GM stuff. I was thinking about tracking down some Mobil 1 this time. Any opinions? Any other suggestions?
    Thanks.
    2002 D/A, Crew Cab S/B 4x4, Light Pewter Metalic, Built 10/12/01, Arrived 11/07/01, LineX, Husky Flaps, Husky floor liners, Lund hood protector, A.R.E. 'Z' Series cap, AutoMeter Boost and EGT gauges, Prodigy brake controller, Cougar 294rls. Member #5013
    Mobil 1 is good stuff. I use Amsoil, but know of a lot of folks using Mobil 1 without issues. It would be my first choice, if Amsoil weren't available when I need a change. You'll need 75w-90 for normal use, or 75w-140 for extreme use (hot climate, frequent very heavy towing, etc.).
    May 2001
    Morgantown, W.Va. USA
    x2 on this!
    But, purty much any synthetic that meets the GM spec will work. I too am running the Amsoil 75w-90 and it's pricey when you include shipping.
    I'm thinking next go round I'm gonna try the synthetic Super Tech 75w-90 that Wal-Mart sells it is waaaay cheaper and it meets the GM spec. If you are cost conscious and wanna save a few bucks this might be the way to go.
    Jeff
    2013 Caprice PPV 6.0L
    Thanks for the input. If I can find it around here, I am going to try for the Mobil1. If I can't get the M1 without a bunch of running around, I'll go for something else that meets spec. Thanks again.
    May 2001
    Quote Originally Posted by Dawg View Post
    Mobil 1 synthetic is top shelf stuff, can't really go wrong with that! When I did mine this past fall I couldn't find enough of the Mobil 1 syn at any given time to go that route. Same goes for the Valvoline synthetic, so I just ordered 6 qts of Amsoil. Like I said though I may try the Super Tech synthetic at Wally World...it's ALWAYS available.
    Jeff
    I have gone with Amsoil, Mobil, and GM synthetics...but the one thing I never do with all the heavy towing miles is let it get past 50K miles.
    Never.
