Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Make it easy to dispense fuel additive...
  1. #21
    St. George, Utah.
    Talking
    Dmaxprof:
    That bottle is very similar to the bottle that I described in the above post.
    The one that I use has the same type of bottle on a bottle and is marked off in ounces 1 thru 4. By tipping over the bottle, fluid will fill the attached bottle to exactly 4 ozs. Being marked off 1 oz increments makes easy to dispense in lessor amounts for maybe a half tank of fuel.
    It works very well for me.
    Denny
    2018 GMC Denali HD 2500 L5P.
  2. #22
    Feb 2006
    Trenton, MO
    The Sta Bil bottle works good. Amsoil's newest additive comes in 16 oz. bottles with a long skinny neck with clear marks every 2oz and a treat rate of 1oz per 5 gal. works real well also.
    Dad's truck
    02 GMC Crewcab Dually Duramax Allison 4x4
    Amsoil Ea Air Filter
    Post OEM Mega Fuel Filter;
    FilterMag on Fuel & Oil;
    Fumoto Drain Valve
    Kennedy Diesel Performance ECM
    Gauges; Kennedy Diesel Lift Pump
    Sheffenecker Mirrors
    Sold
    05 GMC Crewcab Shortbed Duramax Allison 4x4...
    Dad's truck also (My daily driver)
    2007 Classic Crew Cab 3500 Dually
    Kennedy Diesel Mega post Fuel filter
    Kennedy Diesel Lift pump & EGR blocker Package & fingers stick
    Bilstein shocks
    Amsoil synthetic oil and filters
    FilterMag on fuel and oil
    Fumoto drain valve
    Amsoil Dealer
  3. #23
    Mar 2004
    South Dakota
    Default 2 stroke mix
    Quote Originally Posted by Kennedy
    I've been using teh Sta-Bil bottle for years now. I recently added another and filled it with my 2 stroke mix oil to help with that and eliminate the measuring cup and collecting dust...
    So John, everyone seems to have a different mix ratio for the 2 cycle oil, at what rate do yoiu mix??
  4. #24
    Dec 2002
    Long Island, N.Y.
    Default Croz
    You may be OK with that , particularly on the Perkins ... i think there was an old VW prescription to add a little gas to diesel for antigelling.
    But i wouldn't add anything thinner than kero to diesel fuel , Kero also to anti gel. And whenever adding a thinner , a lubricity additive is prudent for wear aspects.
    tom m
    '95 6.5td 4L80E 3500/srw p/u
  5. #25
    Owego, NY
    Interesting Thread!
    I’ve also used STABIL bottles as well as graduated 8 & 16oz (stanadyne) plastic bottles for dispensing fuel additives but as this thread points out, there must be a better way.
    The link DmaxProf posted offers has some interesting possibilities for a “calibrated” dispenser.
    1 gallon jug pump delivers 1 oz. per stroke
    Dispense 1 oz per stroke
    The plunger draws liquid through plastic vinyl tubing from any size container. It has a 3/8 OD intake and discharge. (could get carried away with this one.. …hmmm.. plumb to the fuel filler tube ?? )
    This one found with Google looks good ... similar to the STABIL bottle except it dispenses 1-6 oz
    WirthCo - tip and pour measuring container
    ... also listed on the site DmaxProf pointed us to .. Prop R Measure
    Bill
    98 K3500 6.5,SOLD
  6. #26
    Jun 2012
    erie pa
    Default Measuring Fuel Additive
    Hello,
    I know this is an old topic but take a look at the EzyPor it works great with my additive.
