I don't know how I missed your original thread, but I recently had the same thing happen. It was weird because sometimes it would work and sometimes... nothing. I figured the starter was toast (dead spot?) and then I took a better look at what looked like a tight starter cable connection to the battery. Turns out I could gently rotate the ring terminal by hand - it wasn't loose enough to be able to "rock" the ring terminal, just enough to rotate it. Tightened it up and all has been good.
Glad you got it figured out!
