Results 1 to 8 of 8
Thread: New to the Diesels, With a question!
    Aug 2012
    Florida
    Default New to the Diesels, With a question!
    I recently purchased a 94 Ext. Cab 6.5l turbo/auto
    Firstly i want to make sure that all 3/4ton diesels had the 4l80e, and the truck already has the cat removed and a 3inch pipe back to the muffler (a flowmaster) Will cutting the pipe pre muffler and turning it out the side be a rediculous increase in sound over a catless with a flowmaster? Thanks for the help guys!
    One other thing. a conical racing style filter, is it safe to run without an air box?
    Sep 2006
    They either had a 4L80E 4 speed automatic or NV4500 5 speed manual.
    1990 ¾ ton 4x4 Chevy Suburban
    -Gear Vendors Overdrive
    -Upgraded Holset HX-35 turbo
    -NP205 iron transfer case
    -3.73 gears
    1982 ½ ton Chevy Suburban
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    Aug 2012
    Florida
    I was just ensuring that it couldnt have a 4l60, as looking up the trans filter led me to both results for some odd reason
    1994 Ext Cab C2500 6.5T, the begginning of my dive into the world of diesels
    3" Straight pipe, sets car alarms off...who woulda thought?
    Nov 2010
    rural western Mo
    Greetings vsandme and welcome to the site, this is a remarkable group with extensive knowledge (though I don't happen to be one of them!) I took the cat off my 97 and put a 3 in straight pipe on. Folk tell me they can hear me coming from a block away but it isn't loud in the cab, though I did run it out the back. Good luck with your mods. Greatwhite and some of the other racer guys can speak to whatever you want to do to your rig speed wise, they are awesome help.
    CCC
    _______
    1997 K1500 6.5 (S) 4X4
    1976 Pete 359
    1958 Dodge Powerwagon 4X4
    1986 Am Gen M925 5Ton 6x6
    Lubbock TX, USA
    94-95 6.5's could be equipped with the 4L60E but only if they were the NON-Turbo version. All the Turbo 6.5's had the 4L80E for automatic.
    J
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    Aug 2012
    Florida
    Thanks guys! i removed the muffler today and now its free flowing and sounds great... I plan to build on it slowly in time
    Quote Originally Posted by john8662 View Post
    J
    It seems the Canadians got almost all of the non-turbo 6.5s w/the 4L60-E. I haven't talked to anyone in the States, that I remember, who has such a truck that didn't originate in Canada.
    The 4L60 has an advantage.... It's more efficient in a light duty truck - for fuel economy.
    Aug 2012
    Florida
    counted the pan bolts anyways and of course an 80e. Fuelmileage would be helpful but I believe the 60 has 2 less clutch plates in OD making it a bit weaker. Though I could be wrong, thanks for the help
