Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: No low beam headlights 2008 Kodiak 4500
    Oct 2002
    USA
    Default No low beam headlights 2008 Kodiak 4500
    No low beams. Replaced both low beam bulbs. Have all bulbs lit on high beam selection. Have daytime running lights. But when you select low beams only just have the marker/tail lights and no head lamps. I also checked all fuses. aAnd the DRL relay is OK. I'm thinking the high low selector switch is bad? And not the main headlamp switch? Any Techs please chime in. Thanks
    0000000
    St. George, Utah.
    Wink
    The low beam lights work through a relay that is located in a panel in the pass side dash below the air bag. There are two captured #10 bolts in the bottom edge of the panel. There is a fuse and relay location ilistration inside of the panel.
    Denny
    2018 GMC Denali HD 2500 L5P.
    Oct 2002
    USA
    Thanks Denny, I checked those fuses. I think the relay is the DRL. Any other relays or idea's. Thanks
    0000000
    St. George, Utah.
    Do you have DLRs? Chances are you don't. If you don't change the DLR relay if your fuses are good and you should get both lows and DLRs. Let us know.
    Denny
    St. George, Utah.
    Further make sure that your parking brake is fully off for the DLRs to come on.
    Denny
    Apr 2010
    I seem to remember reading several posts about a wiring harness on the fender well chaffing on some kodiak models and weird lighting issues.
    Might be worth a poke around the engine bay to look.....
    1998 k2500
    Oct 2002
    USA
    Angry
    Thanks I'll check the harness out. I do have DLR's and I did make sure the Ebrake is off. I just don't have the low beams. It's wierd. I think maybe it's the high low switch in turn signal lever. I guess I have to pull the wheel and r&r it. Thanks
    0000000
    St. George, Utah.
    Question
    I've looked at the wiring diagram and what I see is that if you have DLRs you are getting power to the low beams. The low beams get there power through the DLR relay. It almost has to be a bad relay.
    Denny
    Oct 2002
    USA
    Ok, I had swapped out the reverse relay with the DRL relay. They both use the same relay. I wonder if they could both be bad?
    0000000
    St. George, Utah.
    Question
    Not likely. Back in the diagrams I go.
    Denny
    Oct 2002
    USA
    Thanks, I also tried using my Tech II but didn't have any luck.
    0000000
    St. George, Utah.
    Question
    Do you have High beams.
    Denny
    Oct 2002
    USA
    Cool
    I have high beams and all four bulbs work for that. if you flip the lever to low beams they all go out. If you turn the headlight switch off and E brake off I have DRL's. ???????
    If I turn the switch to parking/running lights I get the DRL's which look like low beams. ???? but if you rotate it to headlights it has no low beams. And only high beams if you flip the turn signal high low beam to high beam setting. ????
    0000000
    St. George, Utah.
    Question
    I think that the DLRs get there power through the dash sw when it is in the off position. That being said you have high beams and not lows. It is my opinion that the high/low stem sw is ok. The DLRs have to go through the low position on the stem sw. It is my opinion that the dash sw is the problem. just sayin.
    Denny
    Oct 2002
    USA
    Thanks Denny. At least it's the easier switch to replace.
    0000000
    St. George, Utah.
    Wink
    Before you replace the sw make sure that was plugged in properly.
    Denny
    Oct 2002
    USA
    Did that thanks
    0000000
    Jun 2013
    San Diego, CA
    Default What was the fix?
    Can someone tell me the fix on this one?
    Nov 2015
    texas
    Anybody figure out the remedy on low beam problem ?
    Jun 2002
    MINNEAPOLIS,MN
    Default low beam issue
    the few times I have seen this, the 5-pin relay for the headlights or low beams got switched somehow with a 4-pin relay...usually swapped with another relay next to it...weird things happen, much as you describe...
    SID 6.5 THE DIESEL GUY AT ROSEDALE CHEVROLET IN MINNEAPOLIS...
