Originally Posted by
More Power
Thanks for checking in! Good to hear from you. I'm sure most here like seeing what others are doing, even if it's a Ford....
Ditto! We don't hold grudges against anyone.... As long as you have a diesel, you're always welcome!
PS... I still have my '97 TJ with the 4 cylinder. Odometer shows 197K miles on the 2.5L, and still running strong.
