Originally Posted by
Bigshankhank
I sorted this out, fwiw. Its such a royal pain to get all three pulley assemblies loose and actually moving but once I had the belts slack, I got everything nice and tight down to a 1/4" deflection per my manual. What worked best for me was to tighten the PS pulley, then the A/C compressor, then the alternator (which has it's own belt anyway).
I found that the Power Steering was always the most difficult to tighten. I sure do like the serpentine setup on my 6.5L!!
