Question no start 03 duramax and I'm stumped
Okay gentalmen and ladies I have a 03 duramax lb7 truck was running fine then just started to not want to crank. So here's what I got not wanting to start but will when it's cold drive it for 5 min and kill it it won't start back till a couple hours go by. Using my ppe xcelerator duramax tuner to read my fuel pressure and injector pressure I'm getting in the 850 range trying to crank on rail pressure and 8.1 on injectors and 14,4 with throttle down trying to crank. That's when the truck has been drove. Now I'm no diesel mechanic but doing my own work replacing parts as they go bad and trying to learn about this truck so if someone could help me out on this it will be much appreciated and if y'all need more info plz ask and I will see if I can get it....not losing prime, no codes, and black smokes when it is running going down the road when foot is on throttle I have had people tell me its my injectors but if it was and injector wouldn't it be showing a different reading???
