Am I correct in assuming that by pressurizing the tank if air is leaking then that is my problem? It sounds like there is air leaking from the top of the tank but I cannot see anything. It looks like I have some stains on the side of the tank that I assume is from fuel leaking when the tank is full. I am losing prime at the filter on a stock LB7 02 Sierra. Any input would be appreciated.
