I had one injector set replacement, and thought it would be the last. Can't believe that is all they offered you for the truck. I've got written confirmation of $11,000 for trading my 02 if I want to. Anyway, my truck is now starting to smoke at idle, but not white like it did before needing the injectors replaced, it's has a slight blue tint to the smoke. Surely the rings haven't started to go already. Any idea's? It still hauls good if you jump on it. Only about 40,000 miles on the replacement injectors. Could the fuel suppliers be adding more oil than they did before? I think around here most of the diesel has somewhere between 10 and 15% biodiesel. I just don't know what to think.
