Any time you are going to move the slave cylinder you MUST remove the line at both ends. Both master and slave are plastic and ANY side loading will result in one or the other failing.
I had to drive across San Jose in rush hour traffic with a broken master after doing a clutch change. It is not fun and ANY movement in the line will cause cracking in one end or the other.
