I'm changing rear brakes and wheel seals on my '83 K10 Suburban. I cannot find the right seal. You pull the axle shaft out and the seal is right there at the end by the wheel.
My old one does not have a legible part number but does have the measurements on it, these measurements do match up to what I measured with a caliper.
OD: 2.250" ID: 1.633" Width: .315"
All the parts stores list a seal that is 2.5" OD. Even looking through the book by dimension we can't find a seal that will work and is available.
Has anyone ever had this issue and know a good part number? Or atlas shed some light on what I have going on?
Thanks,
-Colin
