I have done this swap in m y truck and a couple others not sure how you want to go about it but the easiest way is to use the 96 and later trans with the internal slave get a set of hydraulic pedals and adapt the 80s style clutch master to the line for the nv4500 or adapt the newer master to fit the truck I have alost dont the earlier model nv4500 with the external slave 92 to 95 if you got a 4x4 it will not clear the front driveshaft unless you got a suspension lift now my conversion is the dreaded one that they will all tell you NOT to do I used a 92 model from my 2500 that I sold and kept the trans for my 82 then I picked up an advance adapters bellhousing for peanuts online just the bellhousing then I took the front shaft bearing retainor and turned it on a lathe nearly 3/16 of an onch till it fit snug in the bell housing then replaced the 8mm bolts with bolts with allen heads for clearance then we made a pivot stud and used a stock 4 speed clutch fork now I had to grind alot out of my universal chevy 4 speed bellhousing to accomodate the larger diesel starter this was a pain in the short hairs cause it was the one thing i overlooked before i put it all in the truck I used the stock th400 xmember and np 208 transfer case and stock nv4500 trans mount frm the 92 all fit like a glove like it was made to be no driveshaft mods were required at all I am using all mechanical clutch linkage like what an 82 pickup would come with from the factory and best of all the same year clutch its not much of a mongrel at all it looks like it
![Cool](images/smilies/cool.png)
came in the truck I have some old pics of the swap I will try to post what you use for a trans and whats in your truck and how you want it are the big objectives.
