2001 LB7 low oil message.
Hey all,
I've had the "Check Engine Oil Level" intermittently over the last 12 months. I unplugged the sensor at the pan and jumped the connection. This worked for a while, recently intermittent "Check Oil Level" message startef again. Now it is on permanent. This tells me there is a break in the wiring harness somewhere.
My question to you all is: where does the oil level sensor harness plug into on the other side from the sensor from the oil pan?
I'd like to bypass all together and eliminate the message.
Thanks in advance,
Mal
2001 2500HD LT 4x4 SWB Ext Cab D/A Onyx/Graphite CoverMaster Cap, Cord lighted Boards!<br />2000 HD Softail 1550 Kit, SE Heads, SE 258 Cams, HSR42 Carb, 103Hp/105lbFt @ RW! STOLEN in Daytona ....crap.<br />2002 Polaris XC800SP 1.25 Track, Edge Suspension, Clicker Shock, Sonic Blue X Graphics!
