Hi Kappy
The 4-71 Detroit diesel is a 4 cylinder with each cylinder 71 cubic inches. similar to the 8v71,as they use the same cylinders.Not a real powerhouse,but should be good at leaking oil
.Detroit's used to be referred to the as the "green leaker".Some have a turbo added as well as the supercharger.Then it becomes a 4-71T or if it is v configured 4v-71t.
If you can find a older diesel wrench he or she may be able to squeeze a few more ponies from it.Beware doing any injector work on it.If you don't set up the rack right on it,you can get a runaway engine that will destroy it's self if you can't shut it down.Been there and it's scary.
But the old Detroit will take a licking and keep screaming away for years.
I was taught when you drive a truck with a Detroit,slam your fingers in the door so you drive the truck pissed off at it.The only one in my fleet now is in a Champion grader it is a 6-71.
I was told to only use straight weight oil in them like 30w or 10w in winter.15w40 or any other multi grade will just leak extra oil.I found that to be true in my 6-71T that i had in a Ford L 8000.It would leave a puddle out of the air box that looked awful,switched to straight weight oil and it almost disappeared.
Thomas
