Results 1 to 8 of 8
Thread: Replace Injection Pump?
    Aug 2005
    Default Replace Injection Pump?
    Have been living with the DTC 35/36 trouble code for thousands of miles now. Only driveability issue is with the cruise control which shuts off when the SES light blinks on. I've tried everything else, like replacing the lift pump, relocating the PMD under the front bumper, swapping out the PMD, rechecking all of the grounds, new fuel filter, gallons of diesel-clean, etc. I'm thinking it must be optical sensor.
    Except for that, the truck runs better than new. After installing Heath's recommended chip upgrage 5 years ago, it starts quickly with little or no smoke and runs in all kinds of weather better than ever before.
    What would you do? Should I leave well-enough alone or do an expensive pump replacement? Is there any other reason to change out the pump other than to have cruise control?
    Black 95 6.5TD, 929 block, 173k miles, 65k on IP, 48k miles on self-rebuilt engine done in '09, 6 L&S Full-torque inserts in outer main crank holes, Clearwater heads, Fluidamper, rebuilt NV4500, 3" downpipe, 4" exhaust, no cat, dual T-stats, 9 blade fan, spin-on 180 degree clutch, Heath hi-flow water pump and turbomaster, PMD relocated, OPS relay mod, Heath PROM upgrade, and Kennedy headlight harness upgrade soon. Now use semi-syn Lucas 2-cycle oil every fill-up which greatly reduces the frequency of DTC 35-36 codes the PCM/ECM throws.
    That's a tough call.
    The 35/36 code is all related to the pulse width signal from the fuel solenoid.
    Likely not the optical sensor. Those usually set a 17 (High resolution fault)
    The solenoid operates very fast inside the pump as it regulates fuel flow to the pump plungers.
    If the computer does not see the expected return signal it sets the code (ses)
    Have you tried adding a real good lube to the fuel to see if the incidence of the 35/36 setting changes ????
    A slightly sticky fuel solenoid or a little wear in the thing causing fluctuations that fall outside the parameters in the computer programing will/do/can cause the error codes.
    If you have not tried some lube, if it were me I would dump in a couple quarts of good old Tranny red juice.
    There are lottsa fancy fuel treatments out there, but good old tranny oil will do the trick.
    If some lube helps slow down the incidence of the codes popping up you will then know what it is.
    The other possibility is that the ECM (COMPUTER) has an issue.
    You might want to beg borrow or steal another ECM and try it and see if the issue follows or goes away.
    Even a stock ECM will let you test and see if the issue is the IP or in the ECM itself.
    If these tests reveal no change then comes the time to make the tough call.
    It would be a real beotch to replace the IP and then have the same code show up again.
    My gut feeling since you are not having driveability issues is that the solenoid response is just barely outside the spec.
    PMD's can set 35/36 but it is rare to catch it, as normally the engine dies before the code can set.
    Good luck and keep us in the loop.
    Aug 2005
    Thanks for the advice, Robyn!
    The only lube I've tried is the blue 2-cycle engine oil, routinely a pint per tank with no change in symptons. I'll give some tranny fluid a try. I've got some left-over full synthetic tranny fluid on hand, would that be safe?
    I'll see if I can get hold of a spare ECM someplace too. Thanks again!
    A pint is pretty thin.
    Dump in a couple quarts of tranny oil when ya fill the beast.
    Back when I had the big rig with the 500 Cat I used to dump in a couple gallons of tranny oil in each tank twice a year to keep the injectors spiffy clean.
    More often if I was forced to use BIO FUEL
    That stuff was on Cats list to avoid if possible.
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    A pint per tank is not much, might be good for adding a little to the dry fuel we have but probably not enough to make the difference Robyn is talking about.
    About twice a year I use 2-3 quarts of tcw3 rated 2 stroke oil. It has high detergent and is designed to burn in engines. That's what its for, cleaning and super lubing internal combustion engines. I try to find some that is clear or not dark color. It might just be my imagination but I think the trucks run stronger on that tank.
    Every tank gets a 1qt mixture of cleaner/lube and 2stroke.
    Good luck!
    2022 Toyota Tacoma
    2013 Chevy 3500 LB SC SRW 6.0gasser
    2001 Chinook RV, V10 gas
    2007 John Deere x7348 Diesel lawn mower
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 2 dogs
    Sep 2006
    Brooker, FL
    As a recovering fuels and lube engineer, I agree that tranny fluid should be avoided. The TCW-3 2-cycle oil is a better choice, as it's designed to be burned; ATF is not.
    Dec 2000
    Walla Walla WA
    I too have been having the DTC 35 lately. I don't drive the truck much and have neglected adding fuel lubricity formula. After the 8th time being stranded with sudden complete engine shutdown I went and bought some Diesel Clean. Poured the whole qt in and the next tank full. Problem went away. Thinking optical sensor needs a little "dirtiness" to function and fuel solenoid received some needed lubrication.
    BTW, I'm running a rebuilt pump with the Grey Stanadyne PMD mounted on the side of the pump.
    1994 K2500 ext cab. Recently repowered with; Non-cracked 599 block, factory compression, used old DSG girdle for main caps. Factory for what remains. Changed diffs to 3.42. Fuel economy Hwy 22.5 mpg US, in town without lcokup in 2nd/3rd - 18 mpg US.
    1994 K3500 CC LB Silverado. Next project. Built for endurance, power and gearing. Plan on opened up intake and exhaust sytem, best cooling mods, 4.11 gearing 4L80E, followed by Gear Vendors OD. Need to be able to split all gears and have lockup in 2nd/3rd/4th. Tan interior cloth, Bad ass dark blue (coming) aluminum wheels and air ride (coming)
    Aug 2005
    Default DTC 35 Gone w/Lucas Semi-Syn 2-cyle oil
    Can't really believe this happened yet. I've been living with that DTC 35 code problem for years now. Following advice, I added heavy doses (up to a gallon) of standard dino TCW-3 with no noticeable change in driveability. As described, the DTC 35 code would go on and off intermittently, killing the cruise control if it was engaged, especially around the 1750 rpm mark. Only reliable time for using cruise has been under heavy load like towing or against a strong headwind, but DTC 35 would still trip on almost any downgrade or deceleration. No other drive-ability issues whatsoever.
    Went in to get my usual dino gallon of TCW-3 at the local farm/ranch store and saw this Lucas stuff on the shelf next to the dino. A full $10 per gallon more than the dino, but it was rated for chainsaws & motorcycles and I needed chainsaw oil anyway. Dumped a little over a quart into my half-tank full K3500 and started driving. Of course, got the code a couple times in the first 100 miles or so, but then it went out for good!
    Now, after some 400 additional miles, long up and downgrades, cruise control on - still no code!!! And I have not yet added any additional Lucas over that first quart!!!! The label on the LUCAS promises everything, but didn't mention my 6.5 code problem! I'll let you all know if it quits working and the code comes back. $10 extra well-worth the cost!!!!
