Originally Posted by
richp
..... hundreds of miles later, near Joplin, MO....
You were in my neighborhood! I assume you were traveling down I-44. I live just a short distance from Joplin, and work in Carthage, just off exit 18B on I-44. Glad you got it fixed and made it home safely.
