Welcome! Thanks for the pictures and story! Wow! That lower control arm is scary. Very fortunate you made it back home in one piece.
I replaced all the ball joints, tie rod ends, control arm bushings, pitman arm, and idler arm on my '95. My steering is very tight. It doesn't take much slop in each joint to add up to a loose steering feel.
