![Quote](images/misc/quote_icon.png)
Originally Posted by
JeepSJ
I wish I could find the notes I made about what holes I pulled the bent pushrods out of when I took the top end apart a couple years ago.
Sounds like this engine has had this problem for a while then. Valves hitting a piston will definitely cause bent pushrods.
