Yessss
The mechanical IP uses the cold advance and fast idle.
Simply reconnect the wires that came off the switch on the RH rear of the head by the glow plug.
The wires at the IP split and connect to the cold advance solenoid and to the fast idle solenoid.
A manual momentary switch is the best for the glow system.
A Ford starter relay and a momentary button to activate it.
