Hi 3x3
I brought it up because when i got my tow truck the rubber was gone out of the passenger side engine mount.When i would put it in gear with a load on the engine would lift up on one side.If i remember it was the pass side that would lift about an inch or so.
I think that there is a chance of the fittings hitting the frame under the right/wrong situation.When the oil lines break/disconnect the oil loss is quick and usually causes an engine failure if it goes unnoticed for a few seconds.
Thomas
