I tried using an aftermarket fuel pickup sending unit once, and ended up having a ton of issues getting fuel to flow. Apparently the sock kept collapsing down when trying to suck fuel out of the tank. I cleaned up the original sock off my old sending unit and reinstalled it. Been fine since, and that was a few years ago.
