Originally Posted by
94GMC2500
The other day I took the fan clutch off and re bent the coil so the fan engages at a lower temp, It might be engaging a little early now. But anyways I can hear the fan roar now where it had to be like 220 on temp gauge to hear the fan and it didn't last long like it was.
I did the same mod on my stock fan clutch a few years ago. Definitely one of the best things I did for cooling capabilities!
