As Robyn & DMax know, this tank is relatively flat on the bottom. "Under trunk" type tank, no bowl for the pickup to sit in. Just a couple of gallons should have been enough. The Tahoe was on my lift during the repair and with the way the short frame of the 2 door swoops up at the back, there is a slight tilt in the way it sits on the lift with the front leaving the floor a few inches before the rear. With the way the tank is shaped, it could cause a little fuel shift, but not enough to keep 5 gallons from covering the pickup. Robyn, you are correct, I need to get it back on there, drop the tank and see wassup! Our Lucerne is next on the lift for a new transmission so it'll have to wait a couple of weeks, but I'll have to do it. The aggravating part is that I set the old and new pickups side by side and they looked equivalent. Original equipment TS1012 fuel sock looked like it should sit in the same spot as the old pickup.
I don't know how it works but is it possible the bypass hose could have a hole in it and it's somehow picking up air? It looked like it was 'tie wrapped' to the main tube and should be picking fuel up very close to the bottom of the tank.
Anyway, thanks for holding my hand as I went through this process. Removing the tank the next time will be much easier!
d
Dave, N9LOV
Member #242
Dave's Diesels:
'97 2 Dr Tahoe, Intercooled,
Kennedy ECM, 4" Exhaust
'02 GMC
